So you are tring to fill a seam that is opening up.
I think that a picture would of helped. I am thinking that you have some bands or it is thru bolted to hold the beams together. I would try to clean out the crack and flush with acitone then tape each side of crack with wide tape. Then I would take 5200 and work it into the crack ( the tape will keep the 5200 from messing up the top wood) in a couple weeks it could be varnish.
