If you use the pipe bender
To avoid kinks or going too far -- Make sure you do it in VERY small increments, and work the bend point along the area you need to straighten. Use a practice pipe or two before you work the stanchions. Also, to avoid crimps it's important to match the radius of the bending form to the stanchion. If the standard diameters don't work you can make one from wood.
