Return to Index
Read Responses
Sometimes heat shrink will pull-off Awlgrip paint from a topside it it's installed incorrectly.
In Response To:
Vents and drains
winter cover is off, need to figure some things out
Stachions - If you need to replace them...
That is exactly the reason I started taking my stantions off for winter storage...
Stanchions
Thanks Larry, we have one just like that at the school
If you use the pipe bender
I wouldn't think the water would do much damage.
I'm sorry Craig. Could you consider
If you hold moisture against the mast it could bubble the paint.
Frame
The varnish issues MIGHT be because of inadequate ventilation
Vents and drains
See Doug's notes below -- it could affect varnish on a toe rail too.
nope
Easy answer
hmmmm, it was gray sort of
