Return to Index
Read Responses
If you hold moisture against the mast it could bubble the paint.
In Response To:
I'm sorry Craig. Could you consider
The towel is not good if the mast is painted
winter cover is off, need to figure some things out
Stachions - If you need to replace them...
That is exactly the reason I started taking my stantions off for winter storage...
Stanchions
Thanks Larry, we have one just like that at the school
If you use the pipe bender
I wouldn't think the water would do much damage.
Frame
The varnish issues MIGHT be because of inadequate ventilation
Vents and drains
Sometimes heat shrink will pull-off Awlgrip paint from a topside it it's installed incorrectly.
See Doug's notes below -- it could affect varnish on a toe rail too.
nope
Easy answer
hmmmm, it was gray sort of
