Return to Index
Read Responses
Yes
In Response To:
Are you sure they didn't provide you the Non-Metric?
Replacing A Cutlass Bearing
Similar to my Tartan 30.
How did you press it in?
I used my shaft
That sounds like a pretty good way to install one.
Didn't need a press.
It's only a "no big deal" until you get
That's my plan, DIY
A yard monkey broke off my stern tube.
Here's another yard monkey story
You can use a section of 1/2 (or smaller) all-thread and a couple of plates of
what I did
Running into cutlass bearing size issue
Which Cutlass Bearing?
Brass, 30mmx45mmx120mm
Vetus is closer to the length, Larry
SG -- That's an awesome find!
You can use the Johnson, too.
The Johnson duramax is what I have
Yes
If you are going to modify something...
The Vetus was just the ticket, job is complete
Yes very unusual
It's no so unusual where the measurement isn't "critical"
Removed Cutlass on Sunday
