If you are going to modify something...
If the bearing you have fits your shaft, and is readily available, perhaps it would be better to modify your stern tube to accept this bearing.
It's a very small amount of material, I think you could do it with a hand reamer.
Don't worry if you make it too big you can always glue it in; Glued into an over-sized tube is a lot easier to remove.
Cheers,
JM.
