maybe they used a BFH (Big _ Hammer) to get the new cutlass pounded in, and broke the bond between tube and the fiberglass? If that's the case I'd haul out at their expense and try to flow some low viscosity epoxy in there to seal it again. Maybe clean up the leak area too, if you can reach it, and use some 5200 where the leak shows.
