Re: Does it look like this inside?
it is exactly like the above pic, I think SG posted,
and no, the gland is not leaking. another post showed a link
of things to read. a bit down is a pic of a contessa 26. that setup,
as far as the tube, is very similar. the leak is to the left, under the tube.
problem is getting at it.
Thanks for that info Brian. am I correct that this should somehow be
pressure tested after repaired???
