"because I know the correct answer can be found on this board!" But will you know which one it is?
I know! It is the one that agree with you. HaHaHa
In a perfect world no problem with wiring this way. I am sure you know you are adding more points of failure doing it this way.
Side note if you have any sensing wires, they still need to go to the battery..
