Re: inverter/charger? Missing the mark
In Response To: inverter/charger? ()
The inverter part of the inverter/charger converts 12VDC from your batteries to 120VAC when you're not plugged in to shorepower so you can run AC appliances.
The appliances you can run depend on the wattage the inverter will supply . . . but it all comes out of your batteries, so use it with care.
