It's usually around 13.2 volts, so the batteries aren't connected unless a charge is being applied and the first battery in the chain has a healthy charge. The advantage of the combiner as opposed to other automatic alternatives is that there are no diodes that might drop the voltage. The relay and sense circuitry is passive.
