 () Teh salt water puomp on our 2003T feed first to teh oil cooler, a tiny heat exchanger buried behind the main salt/fresh water heat exchanger.
The cooler is only about 2" diameter, with a dozen tubes. You can take the front end off if you first remove the alternator. I found a piece of insulating tape about 1" long blocking half the tubes. Also parts of a raw water impelleer that had disitegrated. If you ever have the raw water impeller fail, you will find the pieces partially plugging your oil cooler, and also reducing the flow of raw water through the system.'
