Return to Index
Read Responses
Thanks Ken, do you use it
In Response To:
CP 180 is a bargain
down below or at the helm?
Chartplotter advice please!
I have a CP180
Thanks! I plan to use it
CP 180 is quite simple to use
Garmin UI is totally useless if you want to set up a route
If you think you might ever leave your home chart region...
C-Map regions are pretty large
CP 180 is a bargain
It's topside. Very good sunlight viewing.
I also have a cp180...
iPad
I've thought about...
Well in the case of the iPad...
Ipod touch has an add on for GPS, might work for Ipad
The iPad has GPS receiver built in. What else do you need?
Not sure that this is true GPS...
Yup, it is.
It is true GPS with assisted cold start, and only in the 3G model...
Agree with you RE the cost of GPS...
It's in there
I like their "Stuff" as well.......There was a long range forecast for Apple a few days ago.
I think Apple has learned important lessons
If you only have one -- get one that is waterproof.
I see the CP180 is now waterproof
I bought a Lowrance HDS-5m last spring and it is great...
David, I have a CP180 as well --I like it.
Thanks for that Jud! It sounds
Hi David...yup, taking in the Olympics and, frankly, enjoying the sunny warm weather...
Like our Garmin 276c with BlueCharts very much.
Garmin 541
About half the people we have sailed with over here in the Bahamas
