I didn't say it was wrong.
I've said that in the example you use you're missing lbs? Where did they go?
The load on the mast will be the same weather you block one side with tackle or not. If you split the parts the the load on each part will be different, but the total load will be the same. You're not gaining any thing here except by not having to pull as hard but just having to pull more.
