WM is off the mark. You're 3G is probably BBB
In Response To: Anchor chain question... ()
The mark should be stamped on a flat surface of the gypsy you can see after you take it off. I have G3, BBB 3/8" chain on my windless. The BBB is marked on the gypsy, But,, as many times, I could be wrong.
Todd said the same thing earlier about his windless.
