As stated by Blye...
In Response To: new dinghy ()
it all depends on where you'll be using your dinghy. If you stay in a "pond" like setting with short distances, that hard dinghy with a little motor, or none at all, will work fine. If you plan on getting to the Bahamas, you'll want the 17" tubes and a 15 HP motor. Going 4+ NM in 2-3' of chop is not unusual.
