Typically we figure 8 coats for a decent finish
In Response To: OK, Tom....question ()
A normal annual touchup around here is to touch up spots with 2 coats and then 2 more on the entire surface. In Florida, I would go for a little more coating thickness to get better UV protection. What kind of varnish are you using? The two part finished (Interlux perfection, Awlgrip clear, epiphanes two part, give a harder finish and last better than the one parts.
