We pull the reef cringle down (our tack reef lines run back to the cockpit). I think you can do the same thing. Work with your sailmaker on the whole system.
I think that you can use the system that Paul described with the straps and rings that Paul showed. Or there are other set-ups. The stacking of you main's flaked sail below the luff can be adjusted for.
