Return to Index
Read Responses
GOOD WORDS!
In Response To:
Couple of thoughts
Our Home page
Starting battery questions...
Cold cranking amps is usually the issue
I have twin alternators, twin regulators and
Sounds like.....
For that size engine a grp 24 battery will be fine...
As I posted in a thread below....
I have a 1-2-both switch on the start battery and
Single pole, singe throw......
Greg what is your battery set up?
We have...
Oh yeah the Engal...
200 is HUGE!
As long as we are on the subject....
Of course... ug, what was I thinking...
Gene
On our boat....
Seems to me that as long as never swith the 1-2-both switch while the engine is running...
Couple of thoughts
GOOD WORDS!
My boat didn't have a switch between the starting battery so I put one in.
Yeah it does make sense.
Don't think it's been mentioned yet, but I hope you have fuses in your system...
Not like that.
As long as we're talking starting batteries, I have a question regarding the use of gels...
If you had a separate take-off on the alternator or a dedicated alternator
How about a solenoid to tie the house and cranking batteries together?
Thanks, Hagar - that's a very interesting idea...
I'm not quite understanding your setup....
Perhaps I described that poorly...
The shunt should be connected between
Thanks, but that's not what my diagram from Xantrex seems to indicate...
Will not work properly if Bat 1 and Bat2 not paralleled.
Well, you're starting to lose me with the mention of "electrical engineering"...
Ok, that appears to have two shunts...
It can be a bad ground connection too...
Thanks a lot, guys...
I will once again recommend a DC clamp ammeter..
I agree
"If it's a good one it's a Fluke"....
Jon...
Well, I know that battery SHOULD crank my engine, no problem...
