Frozen drain hose.
In Response To: Deck drain hose frozen ()
I had a cockpit drain hose that froze one winter with the boat in it's cradle. Didn't find it until the following summer - half way from Block to Cutty the boat started taking on water. A following sea was filling the hose which had split between the coils - each sea brought about a cup of water aboard. Some tape was a temporary fix - drain line was run without low points as a final fix. No problems since.
