I'd use Heli-Coils
In Response To: starboard related question ()
They are worth a try and won't be too expensive. You can probably use your existing screws and just insert the Heli-Coil into the holes. http://www.helicoil.in/
https://www.youtube.com/watch?v=RFYa6sjhh_E - The video shows how you use these in a cast engine situation to replace a stripped screw. These are amazing little devices.
