Return to Index
Read Responses
Plastic and nylon hardware will deteriorate rapidly from UV.
In Response To:
I could be way off here but
starboard related question
Re: starboard related question
There are a few products that might work
Barrel bolts are a good suggestion D'Arcy
you gave me an idea
Inspired me too.
I'd use Heli-Coils
Look into threaded inserts...
The reason that I like Heli-coils is they are an expansion fitting that doesn't depend on threading
Actually it does depend on threading. A helicoil needs the hole to be tapped to fit the helicoil.
You're right, Brian. It is "tapped-in"
Yes it does...
As regards galling, don't that gall you?
....I have had small machine screws gall......
My concern with threaded inserts is that in SS they may gall in removing the bolts......
Look into rivnuts.
Galling and inserts
Interesting inserts. How is that done?
Re: Interesting inserts. How is that done?
I'd think brass would be perfectly acceptable on 'catbird' seats. No immersion.
Re: I'd think brass would be perfectly acceptable on 'catbird' seats. No immersion.
What kills brass particularly is electrolysis. 40% zinc goes very fast. I say we need a test.
But really, I swear...it was a brilliant and witty discussion before I hit that doggone clear button
Amen, brother!!
