Common problem
Gene, this is a common problem under sleeping cushions and has little or nothing to do with it being over a water tank. The solutions mentioned by others should give you some relief, but probably won't totally eliminate the issue. I sleep on my settee and have some stuff under my cushion for ventilation. It keeps the cushion dry, but water still condenses under it.
