Return to Index
Read Responses
Wire stretch?
In Response To:
Sailing without a main and headstay sag
That's puzzling
Re: That's puzzling -or does the boat have a fractional rig? so the top of the mast can bend forward
Fractional rig
I think that's not exactly so.
Re: I think that's not exactly so.
Wire stretch?
Re: Sailing without a main and headstay sag response to comments
Did you learn anything from the surveyor, Neil?
Re: Did you learn anything from the surveyor, Neil?
Deck stepped or keel stepped?
How much of a kink?
Re: How much of a kink? The kink was hidden by the mast boot . . .
Few masts are straight.
1800#'s doesn't seem that much to me to really flatten the sail. (860 Kilograms)
Our boat has a lot more to flatten the 100% jib.
Of course, not in this apparent wind situation :^)))
Don't know Malvina.
I think that's Neil's boat
Love the spinnaker.
Re: Sailing without a main and headstay sag / Did you check
Be careful sailing with big jib and no main.
Re: Be careful sailing with big jib and no main.
makes sense to me
Your ketch has a shorter mast than a sloop, eh?
Should clarify.
Re: Sailing without a main and headstay sag . . . thermal expansion?
Decimal Place Issues
Decimal place
Aside from other issues...
Re: Aside from other issues... -- good points
