I think NOT.
Use a couple of vented loops...Run the lines back toward the exisitng "exit" hose. ON THE DOWNSIDE (after the high vented loops) - put a y-fitting and use that.
Having said this, it's really not a good idea unless you really have NO OTHER CHOICE. You could be pumping water back on yourself if you have a blockage in the outflow.
