Return to Index
Read Responses
The "head" pressure (if the manual pump isn't a two chamber pump) would hugely degrade the electric pump performance
In Response To:
I think maybe YES.
can you run a bilge pump output through another bilge pump?
I think NOT.
I think maybe YES.
I suppose you could but why would you. If
This is very interesting, same situation
I have that exact setup you described for the Whale
Hey those are some interesting alternatives...
Icebox drain
In my case it would mean running awthartships...
I like the idea of a coiled hose that you
