I think maybe YES.
The manual pump will see the centrifugal pump as a restriction on it's inlet, kinda like a partially clogged strainer. The centrifugal will see the manual pump basically as two check valves on it's outlet. With either pump, you'll get reduced flow. I think you'll have to try it to know if it's acceptable.
