that a tilting mount that requires constant attention to keep it in the sun is a fools errand when swinging at anchor. A better solution is too purchase a couple more panels for about the same money. Mount them horizontally and forget them. The extra panels will make up for the less than optimal angle and prevent you from being a slave to your boats electrical needs.
