power take off
On a Yanmar 4jh3 you are allowed 8 hp power take off in the lateral position, this is close to 6000 watts or over 400 amps at 14.4 volts. I do agree that the multi-rib type of flat belt is the best way to go, you need much lower belt tension that way.
