And you get free rod holders out of the deal. What are the dimensions of those panels? Maybe the 50 watters available today are about the same size.
So can I have fishing rod holders all over the boat each with a panel? Hmmm.... 6 x 50 = 300
Maybe Salvador Dali and I will get together and drape a few semi-bendable ones over the bimini and on the deck. No problem as long as they're lashed down. I'll be disowned by the Malo factory, but it's all in the name of getting away from the dock.
I didn't get the "agricultural" reference.
I can't quite see how the tubing extension works. Your other photo shows the panels almost down on the deck. Did you have a way of swapping in a shorter tube extension?
