Return to Index
Read Responses
He wrote it came with VNS
In Response To:
I thought he was asking about the manuals for the 'radar unit' -- not VNS?
Just trying to help him. He's going to encounter activation issues if he's not prepared.
Service manual for RadarPC
We got it. Kudos to Koden
Some good follow up advice too
RADAR PC
And where did you steal this unit, Sylvain
do you have a bill of sale from the last registered owner?
Manuals as PDF and a few notes
Nobeltec is particular about that.
He did say "it was never installed'...So Sylvain...
More on the RadarPC
(Message Deleted by Poster)
Noland NM42U
That's useful but I think you will still need the RS-422 conversion box
RS-422 to usb for $14
Call Nobeltec. They need to give you an activation code for RadarPC
NMEA 0183 is RS-232...
NMEA 0183 is a combined electrical and data spec that uses RS-422
RE: NMEA 0183 is RS-232
Every NMEA 0183 I have used...
So who follows the spec?
Look at the NMEA 0183 connectors on Raymarine or Furuno
A bit confusing...
Our similar unit requires that all is powered downwn, power up radar, wait a minute
low voltage
Suspect it's the software or intiiation sequence
It's true that Nobeltec will only work with data sources it sees on program start up
Yes, you might be able to reinitialize...but
He might have a long cable run to the radar scanner
It's not on the boat yet...
One other consideration
The message I deleted
