autopilots - the install manuals are online. You will see the NMEA 0183 ports all labeled correctly with +/-. The Furuno 511 also has a separate RS-232 port with NMEA-0183 data on it. In most cases you can use one side of the 422 data to connect to an RS-232 port and it will work.
Paul L
