That's what mine cost from them. Ours is a 40,000 lb 50' boat so yours should be less. Ours are 3/8 x 2 1/2 x 18" with 6 holes 7/16". I sent them one, they matched it and sent 7 back in 2 weeks. Only problem was I thought the backstay plate was the same but it's not so I had to have that one made again. The good part about Southern California is that you can drive to Garhauer in about an hour.
