I need to do the same thing, where did you get the foil Max ? And Greg ...
In Response To: Replacing copper ground strap ()
... which corrosion spray product did you use ? I've used the Krylon Clear Coat on my refrigeration copper lines, but you're right, a bit of contrast would be a good thing, with the Krylon, hard to tell what has been sprayed. Thanks, cheers, John
