Return to Index
Read Responses
I'll confess to a little Dr. Electron flash with that one
In Response To:
"Devolve", huh? Hell, that sounds suspiciously like Dr. Electron, no? (grin)
But whenever I hear Devolve I eventually end up here.
Replacing copper ground strap
I think....
What spray on do you use?
I am....
I haven't tried the CRC
PS did a test and Corrosion-X came out on or near top
I do have...
I need to do the same thing, where did you get the foil Max ? And Greg ...
I use Wynn's Viscotene
Good question, John
According to this source, 5 mil and 2" is the way to go
I would like to know what he means by "devolve."
thanks Max, great post ! Cheers, John
ground strap
I was wondering what to do with an ecapsulated keel...
Drilling for lead!
Visions of oops... water... dancing in my head.
No thoughts on the usefulness but drilling for lead would be easier if....
The thicker the better...
I've coated my foil with automotive chassis undercoater...
Drilling for Pb?
Yup, the old "capacitor" trick.
Knife Switch ....
Rich - where do you install the knife switch?
any place in the ground circuit but far enough away from the HF so that you can receive
