Uh...
Good one on me.
I take your point about applying more effort. A concern is that when the prop does pop off, it will hit the forward edge of the skeg. I won't mind some cosmetic damage, but as you suggest, this force will likely be greater than that. So I am a bit timid. I have been trying to hold a sacrificial board between the prop and the skeg for this reason.
I will try to do more tomorrow as I should have a helper. Many thanks.
