If you set aside the maintenance issues. With a keel/centerboard, not only can you set the board all the way down for optimal upwind performance, and raise it for optimal downwind performance, you can also partially raise it to correct for weather helm by moving the center of effort aft. Like sail trim, it's one more tool to be used for best performance.
