It shows the board has a full foil shape so I'm sure it's a glass composite centerboard. That's fine. It shows the foils sections at point A and B, this should give good lift.
It doesn't show any of the lifting mechanism but it should be straightforward as the board shouldn't weigh very much.
It would be nice to get some feedback from other owners on the centerboard and linkage.
This looks like a shoal draft fin keel so that should give you decent sailing performance with the board up in shallow water. Board down, you should get a good extra lift to windward.
