Return to Index
Read Responses
That's the problem....never seems to be enough depth were you need good reverse control so the board has to stay up
In Response To:
Will have to try that as well. Gene Barnes said, don't use it as a depth sounder.
keel/centerboard?
No expert, but ...
It depends on the boat and the conditions.
Unlike a daggerboard on a dinghy, it's not an all or nothing thing with a keel/centerboard.
Interesting analogy. But what he said.
I forget the boatyard advantage.
A keel/centerboard sailboat is the perfect design.
a differenht perspective
I think on mechanical, just like a rudder, you should build a centerboard like you mean it.
to nasty to risk?
That was dire, sorry. On my boat, the 300lb plus bronze board would just stay down.
Listing info
Nice boat. I found this drawing on line.
Our CB Tartan 40 ...
Another photo ...
Nice write up, John. On our Tartan 37
That's a trick I've never tried(backing board down), thanks Tom
Just don't run agound while backing with board down
If my boat went 10 feet straight backwards, it will be a first.
Have to start every season backing the length of the Mattapoisett town ramp.
Interesting Tom ... I read that somewhere a week or so ago ...
That's an interesting read, thanks John.
Thanks Tom, good suggestion ...
You're right about fin and foil hype
In that context, 60 feet/hr is important.
Tom, in displacement monohulls you're right
Maybe not in the boats we sail
Not just comfort and cost
Not a big thing
