Don't need FLS
> If we had forward looking sonar I think it would have helped a lot. I'm pretty good at reading water but
> the green water of the Abacos threw me off. If you have that equipment you would probably have better luck.
We used a handheld depth sounder from the dinghy a few times to map the entrance to an anchorage. Much cheaper than forward looking sonar. It takes a while if you have to do more than find your way past a hump.
