Return to Index
Read Responses
I used a Dremel prepping for my Tides Marine track
In Response To:
Thanks - seems like Dremel
I used it to grind out the TM track, not the aluminum. It worked well for that.
expanding mast gate
How much material do you need to remove?
about 1.5 Inches Aluminum
Do you have rigger locally available?
Yes, but it would seem like overkill
I know the feeling...
Is the mast painted or anodized?
Anodized Aluminum
How will finish the cut aluminum?
file clean, sand smooth and polish.
Aladoine 1201 ALSO!
How about a pneumatic cutoff tool?
For an inch and a half of track... bit overkill...
Those fiberglass cutoff wheels work well on steel too.
I thought so also but a Dremel is a bit small.
Bolts are hardened and are not aluminum.
True, should have been thinking aluminum
Dan, were you using ceramic or fiberglass cutoff wheels?
Fiberglass and carefully.
I'm old tech and would try to use a drill and metal hack saw blade.
Use a router, but make a jig so it CAN NOT get out of control
i agree...
For an inch and a half of aluminum...FWIW...
6061-T6...
Router with a guide and a carbide end mill.
You can get an attachment for a Dremel
