Return to Index
Read Responses
Fiberglass and carefully.
In Response To:
Dan, were you using ceramic or fiberglass cutoff wheels?
In a way I liked using the disks up and putting a new one on.
expanding mast gate
How much material do you need to remove?
about 1.5 Inches Aluminum
Do you have rigger locally available?
Yes, but it would seem like overkill
I know the feeling...
Thanks - seems like Dremel
I used a Dremel prepping for my Tides Marine track
Is the mast painted or anodized?
Anodized Aluminum
How will finish the cut aluminum?
file clean, sand smooth and polish.
Aladoine 1201 ALSO!
How about a pneumatic cutoff tool?
For an inch and a half of track... bit overkill...
Those fiberglass cutoff wheels work well on steel too.
I thought so also but a Dremel is a bit small.
Bolts are hardened and are not aluminum.
True, should have been thinking aluminum
I'm old tech and would try to use a drill and metal hack saw blade.
Use a router, but make a jig so it CAN NOT get out of control
i agree...
For an inch and a half of aluminum...FWIW...
6061-T6...
Router with a guide and a carbide end mill.
You can get an attachment for a Dremel
