No master battery switch?
Probably happened pretty fast and not the sort of thing you are necessarily prepared for. But on my boat the master battery switch would have turned it off, and the manual injector pump cutoff would have stopped the engine. In that inlet, I guess you would need a paddle at that point because you are definitely up a creek.
