I removed the motor wires at the controller terminals and applied voltage there to test the motor (and clutch). They worked without the controller. I would think that's a valid test of the motor and it's connection wires, but will test again with heavier gauge new wires between controller and motor, after I run the ohmmeter tests of the rudder position sensor that Raymarine suggests.
