Yes, not a 29.9, though there seems to be some confusion when it comes to discussing Bristol 30's. I think the winches could be placed about 12" or so further aft. Which might be enough. Here's the only picture I have showing the winches as they are placed right now. They are hard to see, but the "boxes" I was referring to are sort of visible if you look carefully.
The picture might come out sideways...can't figure out how to change the orientation other than within something like Picassa. Ah, learning curve after learning curve...
