Return to Index
Read Responses
Re: Tractor, must have been / Muffler? It didn't have a muffler, pipe all the way.
In Response To:
Tractor, must have been a different muffler.
Dissecting an antique exhaust system.
Re: Dissecting an antique exhaust system. / I had one of those and
In 1962, Motor Boating mag. touted JB Beaird Co.'s 'Maxim Marine Silencer', the choice of fine boat
Re: In 1962, Motor Boating mag. touted JB Beaird Co.'s 'Maxim Marine Silencer', / A couple of pages
You show me yours, I'll show you mine
Alright, D'Arcy. We're at the same juncture.
Re: Alright, D'Arcy. We're at the same juncture.
I've ordered one of these.
You could also buy a Westerbeke injection elbow
Might be worth it. All the research I've done, that elbow is the cooling system achilles heel.
Here's that GOB article for anyone interested.
Thanks, amazing article -- textbook.
On the sailboat my system...
I've concerns about the riser putting strain on the manifold connection.
Re: I've concerns about the riser putting strain / My injection elbow is connected
Had to replace mine +20 years ago
Thanks. I see you too braced your riser to the hull.
The strap to that bulkhead helps reduce vibration and joint stress.
I see. Here's the inside of my engine compartment and the proposed muffler/riser.
Re: I see. Here's the inside of my engine compartment and the proposed muffler/riser. / You don't
If I follow you, I don't think that will work on my boat, Steve.
Re: If I follow you, I don't think that will work on my / The blue line, as it leaves the
The exhaust hose is up to the cockpit sole.
Re: The exhaust hose is up to the cockpit sole. You might look at
Thanks for that post Steve
Re: Thanks for that post Steve / Use a 1/4 inch
My riser is ...
Re: Might be worth it. Since you mentioned GOB in your post . . .
I have that issue and the article is timely, for me.
Where did you order from Tom?
Right here from the SBO.
Hamilton sells all that stuff too
I couldn't find Centrex mufflers in Hamiltons catalogue.
Re: I couldn't find Centrex mufflers in Hamiltons catalogue.
