Return to Index
Read Responses
Thanks, amazing article -- textbook.
In Response To:
Here's that GOB article for anyone interested.
Dissecting an antique exhaust system.
Re: Dissecting an antique exhaust system. / I had one of those and
Tractor, must have been a different muffler.
Re: Tractor, must have been / Muffler? It didn't have a muffler, pipe all the way.
In 1962, Motor Boating mag. touted JB Beaird Co.'s 'Maxim Marine Silencer', the choice of fine boat
Re: In 1962, Motor Boating mag. touted JB Beaird Co.'s 'Maxim Marine Silencer', / A couple of pages
You show me yours, I'll show you mine
Alright, D'Arcy. We're at the same juncture.
Re: Alright, D'Arcy. We're at the same juncture.
I've ordered one of these.
You could also buy a Westerbeke injection elbow
Might be worth it. All the research I've done, that elbow is the cooling system achilles heel.
On the sailboat my system...
I've concerns about the riser putting strain on the manifold connection.
Re: I've concerns about the riser putting strain / My injection elbow is connected
Had to replace mine +20 years ago
Thanks. I see you too braced your riser to the hull.
The strap to that bulkhead helps reduce vibration and joint stress.
I see. Here's the inside of my engine compartment and the proposed muffler/riser.
Re: I see. Here's the inside of my engine compartment and the proposed muffler/riser. / You don't
If I follow you, I don't think that will work on my boat, Steve.
Re: If I follow you, I don't think that will work on my / The blue line, as it leaves the
The exhaust hose is up to the cockpit sole.
Re: The exhaust hose is up to the cockpit sole. You might look at
Thanks for that post Steve
Re: Thanks for that post Steve / Use a 1/4 inch
My riser is ...
Re: Might be worth it. Since you mentioned GOB in your post . . .
I have that issue and the article is timely, for me.
Where did you order from Tom?
Right here from the SBO.
Hamilton sells all that stuff too
I couldn't find Centrex mufflers in Hamiltons catalogue.
Re: I couldn't find Centrex mufflers in Hamiltons catalogue.
