With such thin wood, mortised scarf is out.
In Response To: Woodworking question ()
I'd just use a straight scarf joint, each piece planed to about a 10 degree angle and fitted to the next. Make up a guide and use a block plane. A bit of epoxy, clamp between two other boards (with waxed paper), and you're in business.
