Return to Index
Read Responses
Ah. well I didn't work the numbers. It's all about use.
In Response To:
3" scarf in 1/4" thk. would be 12:1 taper
ANd if I may say so, Craig was a bit circumspect about where and what this was for.
Woodworking question
I would start with slightly thicker wood
Is there such a thing as a scarfed lap joint?
With such thin wood, mortised scarf is out.
12:1 tapered scarf
You can scarf it or you can just 45* cut depending on use...
sorry, did not intend to be vague
Oh, man. You're talking about eyebrows?
On scarfing....if you have to add four inches, you can scarf anywhere....
Surprising you can't find the wood and have it milled to your specs.
Erie prices
Teak's about 25 a bd ft here. Is there a hardwoods place near?
For those dimensions .... probably best to buy teak deck straking from such as TDS, etc.
Why not white oak?
No reason not to use white oak...
It doesn't like to get wet in terms of coloring.
Good points
Have you considered using Ipe...
Beware Ipe!
I've noticed it is less available for home decking nowadays around here.
have we found out what this is for?
