You can scarf it or you can just 45* cut depending on use...
In Response To: Woodworking question ()
If you intend to apply this to a surface as trim inside I'd just do like house molding, cut both pieces 45* and then you can use glue in place. If this is to be outside, that can still work but you might like to scarf it. You could easily get by with a two or three inch scarf in that situation.
